SNMP Driver crashes when the project is closed
zenon driver crashes on closing the Service Engine via exit button. This has been fixed.
If the Service Engine is closed via the "Exit" system button, a driver may crash while the active connection is closed. This does not always occur. The error can affect any zenon driver if the timeout on closing the Service Engine is greater than 30 seconds.
This issue has been fixed. Closing the Service Engine no longer causes a driver crash.
Item ID: 269350
Version: 12.00 Build: 180966
Version: 11.00 Build: 176384
    • TIA driver crashes after importing and overwriting existing variables from the TIA project
      Description The driver was closed unexpectedly after a project was loaded and already existing variables were imported from the TIA project and overwritten. The issue has been addressed and the behavior is now as expected. To benefit from this fix: ...
    • Engineering Studio: Add Driver 'Siemens : S7 driver for S7-1200/1500' to Zenon Project - Error when starting driver
      Summary The S7TIA/S7 for S7-1200/1500 driver cannot be started. This issue has been solved. Description The attempt to add the driver S7TIA/S7 for S7-1200/1500 to a project fails in some constellations with an error message (Error code 0x8001011f). ...
    • SNMP Driver crashes due to mismatched agent configuration
      Description The SNMP driver closed unexpectedly in some cases. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software Platform to the latest build of zenon 14 or higher. Item ID: 305311 ...
