Snmp cel traps driver does receive in an infinite loop
In Process Gateway SNMP_SG, the Trap Destination was configured for sending CEL traps. In the SNMP driver the agent was configured accordingly.  Online traps are received in the offline MIB list.
However, the CEL traps coming from the sender system cause the driver to enter an undefined state. The CEL traps are are displayed late.
This error has been fixed. The CEL traps are shown again as expected.
Item ID: 264617
Version: 11.00 Build: 157700
    • Possible infinite loop in the zenon Logic Runtime when IEC61850 Server receives many Select commands
      Summary Under circumstances the zenon Logic I/O driver IEC61850 Server can cause an infinite loop in the Logic Runtime when receives sequence of many Select commands. Description Under circumstances the zenon Logic I/O driver IEC61850 Server can ...
    • IEC61850 Server: a GOOSE messages not matching the definition can cause in Subscriber an infinite loop
      Summary By reception of some incorrect GOOSE messages the zenon Logic I/O driver IEC61850 Server can go in infinite loop. Description By reception of some incorrect GOOSE messages the zenon Logic I/O driver IEC61850 Server can go in infinite loop. ...
    • SNMPNG32 does not receive traps of authentication is off
      Summary SNMPNG32v3 does not receive traps when authentication is disabled. This error has been fixed. Description No authentication was configured for SNMPNG32v3. In operation now no traps are received. This behavior is due to changes introduced in ...
