Smart Objects are missing Logic Programs from referenced SOs when upgraded from zenon 12 to zenon 14
When working with Smart Objects and zenon Logic code, it can occur that UDFBs are missing after updating and saving the smart objects in the zenon project. The compilation of the logic project does not work and shows errors. This issue might also occur in version 12 when variables are changed in Logic Studio via the the function "Edit variables as text".
The cause is an error in the "Synchronization/Saving" mechanism of Smart Objects.
This issue has been fixed. Effected UDFBs are handled correctly and zenon Logic projects in Smart Objects can be compiled again without errors.
Item ID: 273600
Version: 12.00 Build: 206562
    • Renamed references do not rename zenon logic programs when updating the SOT
      Description In a project references of a Smart Object Template (SOT) are renamed. When updating the SOT, zenon Logic programs are not renamed accordingly. The original names are still included. This behavior has been changed. When renaming ...
    • SOT replacing rule does not work after change on SOT if SOT is referenced in other SOT
      Description A Smart Object Template (A) is referenced in another Smart Object Template (B). After changes in SOT A, the already existing Smart Objects of SOT B are unusable. Screens no longer work. However, newly created Smart Objects work as ...
