Smart Object: zenon logic Variables getting deactivated
Smart Object Templates contain structure data types for zenon Logic. When changes are made to these templates, all structure elements in all instances of this template are inadvertently deactivated. These structure elements can not be reactivated anymore.
A warning message is displayed in the Engineering Studio output window for each structure element. This reads for example: "The element name: 'Data.Check.Conditions[0].Value' already exists - it is replaced by '<1926> Data.Check.Conditions[0].Value'".
This issue has been fixed. Structure data types for zenon Logic work as expected again in Smart Object Templates.
Item ID: 260080
Version: 11.00 Build: 117823
Version: 10.00 Build: 119046
    • FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
    • Renamed references do not rename zenon logic programs when updating the SOT
      Description In a project references of a Smart Object Template (SOT) are renamed. When updating the SOT, zenon Logic programs are not renamed accordingly. The original names are still included. This behavior has been changed. When renaming ...
