Smart Object: Released properties Command processing can not been set a Unused
When using Add-In code in Smart Objects, released properties of command processing cannot be set to unused. This has been fixed.
Add-In code can be
used in Smart Objects. Released properties of command processing
cannot be reset to NONE or <unused> for the "nothing
linked" state. However, this is possible for other released
properties.
This restriction has been removed. The value 0 or an empty string are accepted as valid options
for "nothing linked " in released properties of command processing.
higher.
Item ID: 273690
Version: 12.00 Build: 206562
WVS supports basic Command Processing
Summary WVS supports Command Processing. Description The screen of type Command Processing can be called up in the Web Visualization Service. The following are supported: Write set value via the following screen elements: Dynamic text Numeric value ...
Released properties on symbols inside a smart object template do not get updated correctly
Summary Update of the SOT should work correctly also for symbols and released properties in symbols Description Update of the SOT should work correctly also for symbols and released properties in symbols Issue Number: 226418 Fixed on Date: 15.9.2020 ...
FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
Released properties are linked but are not recognised
Description After saving a Smart Object Template without generating the Service Engine files and reopening the Engineering Studio, released variable properties of Smart Objects are not linked even though the property is defined in the instance. This ...
Checklist: Smart Client does not work
