Smart Object crashed during Save all and Compile all
Smart Object crashes when it contains multiple screens and all of them are saved and compiled. This occurs mainly when multiple SOT screens are open, which contain screen elements with associated variables, and at the same time one of these screens is selected in the Properties window.
This error has been fixed.
Item ID: 264315
Version: 11.00 Build: 157700
    • Smart Object Templates: Engineering Studio crashes when importing an XML file which contains an already existing function name in Smart Object
      Description The zenon Engineering Studio was closed unexpectedly when an XML file was imported that contained a function name that already existed in a Smart Object. The issue has been addressed and the behavior is now as expected. To benefit from ...
    • Smart Objects in Smart Objects: Substitution does not work anymore
      Description When linking a Smart Object to a screen or another Smart Object, the substitution does not work correctly. Some elements are not substituted according to the rules. This behavior has been corrected. To benefit from this fix: Update your ...
