Smart Object API : Variable mapping not applied after changing in engineering studio
Changes in the variable mapping of a Smart Object instance are not applied during CSV export via SmartObject Export Wizard. This behavior has been changed.
For a new Smart Object
instance, variables are mapped in the Engineering Studio
via the dialog for variable mapping. Afterwards the option "Use
variable properties of Smart Object" is set. But when exporting to a CSV
file via Wizard, the changes from the Engineering Studio are not applied.
If the changes are set directly in the CSV file
and imported into the Engineering Studio, then the changes are taken into
account during the next export.
This behavior has been changed. Changes for the
variable mapping in the Engineering Studio are taken over immediately.
higher.
Item ID: 256468
Version: 11.00 Build: 157700
Checklist: Distributed Engineering – Engineering Studio cannot connect to the Project Database-Server / Elements cannot be checked-in/out
Time estimate: 45 minutes Please go through all the items in the following checklist. If necessary, confirm any information you cannot verify with the IT department before contacting your local COPA-DATA representative. Checklist usage: #. [Quick ...
Checklist: Engineering Studio cannot start or closes unexpectedly
Deleting of an Referenced Smart Object Template causes Zenon to Crash
