SICAM230 Conversion wizard: Siemens IEC61850 driver(s) cannot be converted
When converting a SICAM® 230 project to a zenon project using the SICAM® Conversion Wizard, the Siemens IEC61850 driver is not converted correctly. No driver connections are created. Variables are not linked to the new IEC850 driver instances.
This error has been fixed. The Siemens IEC61850 driver is converted correctly.
  • Update your zenon Software Platform to the zenon 8.00 build 108427 or higher.
Item ID: 261204
Version: 8.00 Build: 144579
