Service Engine: S7TIA Driver - crashes on reconnect PLC
The Service Engine has a connection to a S7TIA PLC. If the Service Engine loses the connection and the variables get the status "invalid", the S7TIA Driver is terminated unexpectedly after reconnecting.
This error has been fixed.
  • Update your zenon Software Platform to the latest build of zenon 8.20  or higher.
Item ID: 264213
Version: 11.00 Build: 157700
Version: 10.00 Build: 138660
Version: 8.20 Build: 263752
    • Checklist: The Logic Service to Service Engine connection does not work
      Time estimate:   30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Screenshot and followed ...
    • Checklist: Problems of displaying graphics in Service Engine
      Time estimate:  15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
