Service engine crashes when removing columns in AML or CEL
If in the Service Engine in the AML or CEL screen columns are removed from the list while the filter row is active, the Service Engine is closed unexpectedly.
This bug has been fixed. Columns can be removed from AML and CEL again as expected.
Item ID: 281749
Version: 14.00 Build: 239777
    • FAQ: How can I backup the Service Engine data, the data created during Service Engine?
      The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
    • FAQ: How, where, why and when does zenon Service Engine save data?
