Service Engine crashes when reading back AML data evacuated to Data Storage
When an AML or CEL entry for an unknown variable is received from an external storage, the Service Engine logs an error to DiagViewer and ignores the entry.
Issue Number: 246875
Fixed on Date: 29.11.2021
Versions: 10 0 BUILD 92805
FAQ: How can I backup the Service Engine data, the data created during Service Engine?
The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
FAQ: Why do backups of Service Engine data sometimes fail when the Service Engine is running? Is it actually possible to create a consistent backup when the Service Engine is not closed?
During normal operation, the zenon Service Engine continuously accesses different runtime files for reading and writing. A backup software that attempts to create a backup of a file that is currently accessed by the Service Engine may receive an ...
