Send Group, Following Call and Endless Following Call messages don't recognize MC users
Message Control Send Message function does not work for user groups in the runtime properly. Also see #26855.
An issue was addressed in the Message Control module in combination with the User Administration. Now, user groups from the global project can be used properly.
Fixed on 23.05.2012, available from 7.00 SP0 Build 1. It is recommended to use Build 2 in combination with Message Control if you have this issue because the fix of defect #27010 caused negative side-effects which were fixed in Build 2. Also see #26855.
Issue Number: 26921
Fixed on Date: 23.5.2012
Versions: 7.00 0 BUILD 1
