SE: Crash if making the CEL column bigger in the SE
If the size of a column is changed in the Service Engine in
a screen of type CEL that has been defined as the start screen, this
leads to an unexpected termination of the Service Engine. This
bug does not occur in the WVS.
This bug has been fixed. Columns of the CEL can
be resized in the Service Engine as
expected again.
To benefit from this
fix:
- Update your zenon Software Platform to the latest build of zenon 14
or higher.
Item ID: 281908
Version: 14.00 Build: 239777
Runtime crash when opening a grouped column
Summary In the zenon User Administration, the Service Engine crashes during actions in grouped user names. This error has been fixed. Description The zenon User Administration is grouped according to the "User names" column. If one of the group ...
Service engine crashes when removing columns in AML or CEL
Description If in the Service Engine in the AML or CEL screen columns are removed from the list while the filter row is active, the Service Engine is closed unexpectedly. This bug has been fixed. Columns can be removed from AML and CEL again as ...
save after interlock assignment(change) in symbol visibility setting causes zenon editor crash
Description If a symbol whose visibility has been assigned an interlocking is saved while the Interlocking is still selected, may the Engineering Studio cause to crash. This error has been fixed. To benefit from this fix: Update your zenon Software ...
