SE - AML crashes after changing default order and leaving only one column on the AML list
In the Service Engine, the default view of
the AML list is adjusted. All columns
except the first column are hidden. Including the column by which the list was
sorted. As a result, the AML type screen is closed unexpectedly and the Service
Engine is terminated unexpectedly.
This behavior has been fixed. The AML now
displays the remaining column correctly.
- Update your zenon Software Platform to the latest build of zenon 10 or
higher.
Item ID: 259665
Version: 11.00 Build: 115310
Version: 10.00 Build: 116257
Sporadic crashes and freezes of service engine displaying AML or CEL list when AD users are used
Summary Service Engine sporadically crashes or freezes acknowledging alarms in AML list when AD users are used Description Service Engine sporadically crashes or freezes acknowledging alarms in AML list when AD users are used Issue Number: 246421 ...
Filter property page have wrong text for Column Width in columns list for cursor
Summary By changing the order of the cursor output columns, the Curve Name is written in the field for the Column Width. DescriptionBy changing the order of the cursor output columns, the Curve Name is written in the field for the Column Width. ...
Service engine crashes when removing columns in AML or CEL
Description If in the Service Engine in the AML or CEL screen columns are removed from the list while the filter row is active, the Service Engine is closed unexpectedly. This bug has been fixed. Columns can be removed from AML and CEL again as ...
