Screen switch function to Trend with option set: "show header in scan window in compatibility mode" do not show all curves
When enable the settings "show header in scan window in compatibility mode" in the screen switch function to an extended trend screen, the first Curve is overwritten with the header in the scan window.
Correct initial height set for the scan window. All curve scan data are shown now in the scan window
Issue Number: 29239
Fixed on Date: 11.4.2013
Versions: 7.00 0 BUILD 9
