Screen container in faceplate screen, changes size when Service Engine title is active
For screens of type Faceplate,
the screen container in the Service Engine changes its size if a title is
selected for the “Service Engine caption” property. In this
case, the height of the screen container is increased by the height of the
title. If "No title (full screen)"
is set for “Service Engine caption”, then the height of
the screen container remains as defined.
This behavior has been changed. The height of the
screen container remains unchanged in the Service Engine, regardless of the
setting for the “Service Engine caption” property.
- Update your zenon Software Platform to the latest build of zenon 8.20 or
higher.
Item ID: 262313
Version: 11.00 Build: 157700
Version: 10.00 Build: 131739
Version: 8.20 Build: 131082
FAQ: Installation of Service Engine 12 Build 162015 in Ubuntu 22.04 LTS as Docker container
Refer to the attached file: Docker on Ubuntu 22.04 - FAQ.pdf This guideline is solely shared for demonstration and educational purposes. Feel free to contact COPA-DATA Support for further clarifications.
zenon Service Engine freezes when process recorder is active
Description The zenon Service Engine froze when the Process Recorder was active. The Service Engine froze because a Microsoft function runs in an endless loop. The issue has been addressed and an optimization call, which led to the issue, has been ...
