SCL Editor [IEC61850-6]- the scl must not handle an error when checking a private types
When importing an SCL file with Private tags into the SCL Editor for IEC61850 in zenon Logic, a syntax error is indicated. However, according to the standard, errors for Private tags should not be indicated during validation.
This behavior has been modified. Errors for Private tags are no longer indicated.
Item ID: 281751
Version: 14.00 Build: 239777
