[SAP Interface] Values of export parameters of SAP function are not assigned to variables
Two bugs occur in the SAP Interface: In the Service Engine, zenon variables are not updated correctly. And in the Engineering Studio, import/export parameters are swapped when importing RFC function configurations. These two bugs occur independently of each other. Both bugs have been fixed.
Fixed bugs in the SAP interface:
1. Service Engine: Variable update
When executing an SAP RFC function in the Service Engine, zenon variables that are linked to SAP export parameters are not updated. The function call between zenon and SAP server is successful. No error messages are displayed in the Chronological Event List (CEL) or LOG files. However, the variable linked to the export parameter is not updated.
2. Engineering Studio: Import of RFC function configuration
When importing RFC function configurations from the SAP system into the zenon Engineering Studio, the SAP parameter types import and export are swapped. For example, a function configured with two import parameters and one export parameter appears in the Engineering Studio with two export parameters and one import parameter.
Both bugs have been fixed:
  1. zenon variables that are linked to SAP export parameters are updated again in the Service Engine. Linked zenon variables show the correct value.
  2. In the Engineering Studio, SAP RFC function parameter types import and export are imported correctly again.
Item ID: 261744
Version: 14.00 Build: 239777
Version: 12.00 Build: 241649
    • Checklist: SAP Interface does not work
      Time estimate:  30 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
    • [MSI Interface] Parameter values from order parameter messages are not written to variables
      Description In the MSI Interface, parameter values from "order parameter messages" are not written to variables as expected. The LOG file refers to: "System.Collections.Generic.KeyNotFoundException: The specified key was not present in the ...
    • BATCH CONTROL - Function authorization for export of recipes
      Summary Batch Control now has a new function authorization for exporting recipes. Description The export of recipes in Batch Control also allows access to the device's file system. This can now be restricted. For this purpose, the setting "Batch ...
