Sankey WPF always leads to 100% CPU load on virtual CPU0 when active in a screen
The Sankey WPF loads the CPU to almost 100% when it is
active in a screen. The cause was that the refresh rate was not observed.
This behaviour has been changed. The WPF now uses a default refresh rate of 100ms.
The refresh rate is configurable over the WPF Property ELEMENT#zRefreshRate
The minimal valid value for ELEMENT#zRefreshRate is "100" which corresponds to 100ms.
Lower values will be ignored.
A higher value will cause the Sankey to refresh at a slower rate and can therefore improve performance.
- Update your zenon Software Platform to the
latest build of zenon 8.20 or higher.
- Update the CDWPF Control.
Item ID: 264988
Version: 11.00 Build: 157700
Version: 10.00 Build: 153228
Version: 8.20 Build: 150600
EUROMAP63: driver get stuck and cause high CPU load when dat file is wrong
Description The EUROMAP63 driver hangs due to an error in the DAT file. Thereby it causes a high CPU load. The error is caused by unquoted ASCII fields and empty fields. These do not comply with the Euromap standard. This problem has been solved. The ...
Help screen: Alarm-help screen always opens in the most left screen
Description When an alarm has been triggered in the zenon Service Engine, the alarm help screen always popped up in the first screen. The issue has been addressed and the alarm help screen is opened now in the same monitor where the alarm "Open help" ...
Machine Event Counters Report not working any more in zenon 12
Description In Report Engine version 12, the reports "Machine Event Counters", "Over Revolutions on Load Shedding" and "Active Power on Load Shedding" no longer work after they have been updated from a previous version. The error states that the ...
