S7TIA32: Variables cannot be imported from a TIA project which contains DALI modules
Update AGLink40.DLL and AGLink40_x64.DLL to version 5.6.1.3 for debug and release.
Issue Number: 238695
Fixed on Date: 24.3.2021
Versions: 8.10 0 BUILD 81533 | 8.00 0 BUILD 82348 | 8.20 0 BUILD 82266
S7TIA: Variables cannot be imported from TIA project when CPU name contains dots (.)
Summary All Version do not resolve dots (.) as part of CPU-name properly. This leads to problem with importing variables from TIA-projects or pre-compiled projects. With the current bugfix CPU-names containing dots are quoted to recognise it and to ...
Checklist: Workspace/Project cannot be created, loaded or backed up
TIA-Treiber - Import only existing Variables working not correct
Description In the TIA driver the option "Import only existing variables" is activated for the import of variables. This is to import only variables that are existing in the project. However, variables that are not used in the project are also ...
S7TIA: enhancements for TIA import
Summary The variable import for the S7TIA driver has been enhanced for zenon Software platform versions 10, 11, 12 and higher. Description The variable import for the S7TIA driver has been enhanced by the following functionalities: Variable import ...
