S7TCP driver and others : No red square on variables if the hardware communication is not established.
If the S7TCP driver cannot establish communication with the hardware, the red square that is supposed to indicate this is not displayed in the Service Engine. The status display is also empty. This occurs in zenon 12 with build versions higher than 180966.
This error has been fixed. Interrupted communication is signaled correctly again and provided with the correct status.
Item ID: 281450
Version: 14.00 Build: 239777
Version: 12.00 Build: 232473
    • FAQ: Why are there small RED squares on the dynamic elements in the zenon Service Engine?
      Small red squares on the dynamic elements in zenon Service Engine indicate that the INVALID Bit (aka I-Bit) is active for the linked variable. The INVALID Bit is set true automatically by the zenon drivers for variables when there is an underlying ...
    • FAQ: How can I monitor and react on the communication status of my devices with zenon?
