S7 1500/1200 driver, it should be possible to select 'ap14' file
The driver now also allows to select TIA 14, TIA14.1 Projects. So it should be also allow the file extension ap14 for the TIA project selection
The selection for *.ap14 is now possible.
The selection was already possible with the trick of typing *.* into the textbox and accept it. then all file extensions was able to select.
Issue Number: 38734
Fixed on Date: 31.7.2017
Versions: 7.20 0 BUILD 40591 | 7.60 0 BUILD 40751
