Runtime Stops working unexpectedly when removing a variable from a schedule
In the PFS (Production and Facility Scheduler) you may remove a variablesfrom a schedule with the help of the schedule-properties dialog. However, when doing so, the runtime may sop working unexpectedly.
the described issue has been resolved. Removing variables from a schedule now works as intended.
Issue Number: 34797
Fixed on Date: 13.7.2015
Versions: 7.11 0 BUILD 21458 | 7.20 0 BUILD 21629
