Runtime freezes when displaying a report from report generator have not enough space available
When report from report generator function have not enough space below or right to fill up functions to fill up all cells runtime freeze.
This issue has been addressed and the zenon Runtime does not freeze anymore.
Issue Number: 35125
Fixed on Date: 12.5.2016
Versions: 7.20 0 BUILD 24121 | 7.50 0 BUILD 28116
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
Checklist: Update CE fails
Screen switch function for "lot archives" (archive revision, report generator, etc.) are not executed correctly on the Client
Summary Screen switch function for lot archives (archive revision, report generator, etc.) are not executed correctly on the Client. When displaying a filter dialog, there is a short delay, but lots that exist ni the server are not listed on the ...
zenon Runtime closes unexpectedly, if between Report Generator profiles is switched too fast
Summary With too fast switching (via screen switch function) between Report Generator profiles Runtime stopped unexpectedly. DescriptionWith too fast switching (via screen switch function) between Report Generator profiles Runtime stopped ...
FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
