runtime closes unexpectedly on starting a specific batch control recipe under specific circumstances
When starting a batch control recipe in manual mode, while advanced logging in the diagnosis server is active, where the batch control recipe contains more than 8 instances of an operation, the runtime closes with an unhandled exception.
An issue was addressed in the advanced logging in the diagnosis server where the stepping position for the manual mode was incorrect when more than 8 instances of an operation were used in a recipe.
available from 7.00 SP0 build 4
Issue Number: 27921
Fixed on Date: 19.10.2012
Versions: 7.00 0 BUILD 4
