The
Recipe Group Manager required a server-side Active Directory connection to correctly log the Clients User Name in the corresponding CEL entry. If the server could not connect to the Active Directory, the fallback was to use the account that was logged onto the server.
The issue has been addressed and for the case of connection issues now the client's short username is consistently used for both CEL entries and RGM entries.
This only affects projects which use Active Directory as user authentication mechanism.
- Update your zenon Software Platform to the latest build of zenon 10 or higher.
