RGM: inconsistency in the user mapping on the client
In RGM, user assignment to recipes does not
always work as configured. The property “User assignments via“ allows
the selection of Full
name or User name. If the “User assignments via“ property is changed in the
Engineering Studio, then this change is not always adopted on the client, regardless of whether the Service Engine is running or restarted.
This behavior has been adjusted. Changes
to the “User assignments via“ property are now applied to all devices.
- Update your zenon Software Platform to the latest build of zenon 8.20 or
higher.
Item ID: 258975
Version: 11.00 Build: 115310
Version: 10.00 Build: 116257
Version: 8.20 Build: 114526
RGM: If the state of the recipe is changed, User and Date are not saved in recipe
Summary In RGM, recipe changes are not always logged correctly in the recipe. This has been fixed. Description If the status of a recipe is modified in the RGM, the modifying user and the date of the change are not saved in the recipe. The ...
FAQ: Recipes in RGM cannot be edited / RGM incompatibility of recipes between different builds in version 8.20.
There was found an incompatibility in the Recipe Group Manager (RGM) in zenon 8.20 Build 70282, 79336, 80198, 80611 and 81129. An issue was detected which causes the RGM recipes of the affected builds to be no longer compatible with recipes stored ...
FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
