RGM: if signature text edited by the operator is not correctly logged in the CEL on the client
In RGM, the signature text edited by the operator is not logged correctly in the CEL on the client. This error has been fixed.
If a recipe value change with editable signature text is executed in the RGM on the client for "Recipe group - Recipe name  - Recipe variable - Signature text", the edited signature text is not logged correctly in the CEL. Instead the signature text predefined in the Engineering Studio is entered in the CEL but not the newly edited text. If the value change is made on the server, the edited text is written correctly to the CEL. Also value changes with a signature via a value element always generate a correct CEL entry.
This behavior has been modified. The edited signature text of an RGM variable now is written correctly to the CEL.
Item ID: 234447
Version: 8.20 Build: 82266
