Resizing columns in the recipe value list in the Recipegroup manager screen in the runtime does not work correctly after using the scrollbar.
When the old recipe value list in the Recipegroup manager screen in the runtime has a horizontal scrollbar and the scrollbar is scrolled to the right, resizing the columns in the old recipe value list does not work at the visible separators of the column but at the "old" position of the separator before scrolling was performed
An issue has been addressed in the Recipegroup manager screen in the runtime. Now also when the horizontal scrollbar is shown and the scrollbar is scrolled to the right, the columns can be resized correctly.
Issue Number: 33083
Fixed on Date: 10.11.2014
Versions: 7.50 0 BUILD 25796
FAQ: When I activate the option "write synchronously" for the Recipegroup manager recipe, and I write the recipe, the recipe does not seem to be written properly and also the Service Engine does not close properly. Why is that?
When the option "write synchronously" is active at a recipe, when writing a recipe (sending values to the PLC) for each recipe variable a writing confirmation is requested to the driver. On a successfull write, the driver sends a writing confirmation ...
Entering a value using a datatype specific keyboard in the Recipegroup Manager recipe value list allows direct editing of the value as well
Summary When using a datatype specific keyboard in the Recipegroup Manager screen in the runtime to set a value in the recipe list, the value can be entered in the keyboard but also directly in the recipe value list. Description When using a datatype ...
The recipe value table in the Recipegroup Manager screen in the runtime does not display any columns under specific circumstances
Summary When the Recipegroup Manager screen is opened in the runtime for a group that does not contain any recipes, the Recipe Value table is empty and does not display any columns. Also not after a new recipe has been created. DescriptionWhen the ...
Increment and Decrement RGM specfic keyboard screen functions do not work with the new recipe value list
Summary The keyboard screen allows configration of Recipegroup Manager specific functions for incrementing and decrementing the selected recipe value through the keyboard screen. In the runtime with the new recipe value list, the functions do not ...
FAQ: When I change something in the Recipegroup Manager via the programming interface in Service Engine, these changes are not updated in the screen. Why is that?
To understand this, you have to know that each time you access the RGM (Recipegroup Manager), you are working with a copy of the RGM data. So every screen that is opened in the Service Engine, has it's own copy of the RGM data. Also each instance ...
