Report Viewer: Values are displayed as "#Error" after switching to another page.
In the Report Viewer
screen, values retrieved in the Service Engine are displayed correctly when the
report is opened. After a page change, however, the previously correctly
displayed values are shown as "#Error".
This was caused by security settings that are required to execute user .Net
code.
This issue has been adressed. The settings have been
adjusted. Values are displayed correctly again in the Report Viewer.
To benefit from this
modification:
- Update your zenon Software Platform to the latest build of zenon 14
or higher.
Item ID: 280955
Version: 14.00 Build: 239777
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
Release Notes zenon 15.2
In the appendix of this article you will find the revision text for IIoT Services 15.2 in: English German
FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
