A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
Summary The "Report Viewer: export / print" function doesn't work without Report module licensed. It is not mandatory to have a licence for the report viewer in Runtime. Description The "Report Viewer: export / print" function doesn't work without ...
Summary Internal time filters of a report filter will be validated correctly . Description Internal time filters of a report filter will be validated correctly . Issue Number: 242181 Fixed on Date: 2.7.2021 Versions: 8.20 0 BUILD 85568 | 10 0 BUILD ...
