Report viewer rdl automatic template gives error if more than one data set of the same type is used
More than one data type of the same types can be used - but when the user create a new report, the automatic template (generated by zenon) will not work, as more than one item has a the same name.
It is possible to use more than one data set of the same type
All Text get unique names the dataset snippets into the rdl file.
Issue Number: 33830
Fixed on Date: 12.5.2016
Versions: 7.50 0 BUILD 25796 | 7.60 0 BUILD 36068
