Report Viewer doesn't displayed Control Phases Operation name.
In the dataset Batch Control Phases there is a column for the Operation Instance name. Unfortunately the name will only be displayed for PFC Operations. For Matrix Operations the operation name is not displayed.
Operation name in displayed in Batch Report
Issue Number: 38086
Fixed on Date: 29.5.2017
Versions: 8.00 0 BUILD 46644
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
Opening the lot filter in the Report Viewer on a client no report is displayed
Summary When opening the lot filter in the Report Viewer on a client, no report is displayed. This has been fixed. Description In the Report Viewer, if different lots are opened on the server and client, no report is displayed on the client. If the ...
Report Viewer: Values are displayed as "#Error" after switching to another page.
Description In the Report Viewer screen, values retrieved in the Service Engine are displayed correctly when the report is opened. After a page change, however, the previously correctly displayed values are shown as "#Error". This was caused by ...
high memory consumption of recipes containing phases with control strategies.
Summary In Batch Recipes the complete configuration of the included phases is stored including all control strategies, even those which are not active. If for example a phase has 100 control strategies configured in the zenon editor, then only one of ...
