When starting the Report Launcher
under Windows 11, only an error message is displayed. However, the Report Launcher
does not start.
Cause:
By default, an attempt is made to use Internet
Explorer as the browser for the Report Launcher.
This is no longer supported as of Windows 11.
As a workaround, the option “Use system default browser” can be activated in the ReportingStudio settings. This means that the browser defined as the default in the system will be used.
Solution:
This behavior has been changed. The option “Usesystem default browser” is now activated by default. In
addition, this setting is now also applied by default if several reports are
opened simultaneously in the Report Launcher.
