Report Generator: "Set filter" element does not get updated from Time Filter
Report Generator screen and setting a different filter with the screen specific function (Filter...) the used filter works, but the control-element does not get updated.
The screen element for the filter gets updated if the filter was modified.
Issue Number: 35602
Fixed on Date: 26.11.2017
Versions: 7.60 0 BUILD 37399
FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
Function Report execute for a Report Generator report, does not correctly consider the time filter
Summary When a report execute function is executed, the time filter is not correctly considered. Only when the time filter is displayed, the time filter is taken over correctly. DescriptionWhen a report execute function is executed, the time filter ...
The screen switch function to a Report Generator screen sometimes does not save the time filter settings.
Summary The screen switch function to a Report Generator screen sometimes does not save the time filter settings. As soon as the screen switch function configuration is opened again, the previously configuration is lost. DescriptionThe screen switch ...
FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
FAQ: When I change something in the Recipegroup Manager via the programming interface in Service Engine, these changes are not updated in the screen. Why is that?
To understand this, you have to know that each time you access the RGM (Recipegroup Manager), you are working with a copy of the RGM data. So every screen that is opened in the Service Engine, has it's own copy of the RGM data. Also each instance ...
