In the Report Engine, when the SQL connector is
configured for CEL only, all CEL queries fail, regardless of whether the report
also contains AML or not. However, when
the SQL connector is configured for AML and CEL in the same database,
all CEL queries will succeed regardless of whether the report also contains AML or not.
Cause: The SQL table type for the CEL data table is read from the wrong object, namely the AML data table. The SQL Connector for CEL therefore only works if CEL uses the exact same SQL storage database as AML.
This behavior has been fixed. Reports can be created for evacuated CEL or AML data only.
To apply the fix:
