Remote-Transport: no TCP keep alive for listening socket
The TCP server of process zensysSrv (used for remote transport) did not send TCP keep alive messages to check if the TCP connection is still available.
The issue has been addressed by automatically enabling TCP keep alive for the listening socket 1101 of zenSysSrv.exe to clear TCP connections that are no longer available.
Item ID: 288599
Version: 14.00 Build: 314355
Version: 12.00 Build: 301428
    • zenLogSrv: no TCP keep alive for listening socket
      Description The TCP server of zenLogSrv.exe did not send TCP keep alive messages to check if the TCP connection is still available. The issue has been addressed by automatically enabling TCP server now automatically enables the TCP keep alive for the ...
    • In Docker-Compose: no TCP keep alive for listening socket, port 50780
      Description In Docker the TCP server of process zenLogSrv.exe did not send a TCP keep alive to check if the TCP connection is still available. The issue has been addressed by automatically enabling TCP server now automatically enables the TCP keep ...
    • T5BusEIPS: EtherNet/IP Adapter does not make use of TCP Keep Alive
      Description The EtherNet/IP Adapter (T5BusEIPS) does not make use of TCP keep alive messages to check if the TCP connection from an EtherNet/IP Scanner is still OK. The issue has been addressed and the T5BusEIPS enables a TCP keep alive for the ...
    • Checklist: Service Engine files cannot be transferred via Remote Transport
