Remas not exported by the Analyzer Export Wizard
The Analyzer Export Wizard may be used to export variables aith their associated recation matrices (Remas). However, in some cases the Remas will not be not exported.
Due to an internal issue with the access of colors which are used in Remas, the export of Remas may fail when a color palette is used. A workaround has been implemented to achieve successful export of Remas.
Issue Number: 32992
Fixed on Date: 14.1.2015
Versions: 7.11 0 BUILD 17075 | 7.20 0 BUILD 17768
