When an XML file containing Recipegroup Manager recipegroups, which was exported from the editor, is imported in the runtime, the XML import fails and a message "CXMLPort::Process,importing" is recorded in the CEL. Although another message in the CEL indicates the import was successful, the import in fact did not complete.
An issue has been addressed in the editor where the XML export did not create a valid XML file. XML files that are exported with a version newer than the build in which this issue was addressed, can be exported OK in the runtime.
The XML files exported in previous versions of the editor contain the XML "<Nict verwendet>" which prevented an XML import in the runtime. Manually removing this from the XML file is a valid workaround.
Issue Number: 34204
Fixed on Date: 12.11.2015
Versions: 7.60 0 BUILD 36068
