Recipe variables in the recipe value table in the Recipegroup Manager screen are not always correctly set invisible
It can happen that Recipegroup Manager recipe variables are still displayed in the recipe value table in the Recipegroup Manager screen in the runtime, although the linked visiblity variable have an active limit with the invisible attribute set. This condition is more likely to occur when several different visibility variables are used.
An issue has been addresed in the runtime where the invisible attribute for an active limit of a variable linked as a visibility variable for a Recipegroup Manager recipe variable, was not correctly considered in all circumstances. Now the visibility of recipe variables in the recipe value table, on opening the Recipegroup Manager screen in the runtime, correctly reflects the status of the limit.
Issue Number: 37082
Fixed on Date: 19.9.2016
Versions: 7.20 0 BUILD 31669
