RDA Archives are not created after the Server is shut down in a redundant system
Server 2 (or 1) does not generate RDA archives in a redundant system. This has been fixed.
In a redundant system, the server where Service Engine was started second, the RDA variables are not advised automatically. In consequence, when this server takes over as primary server it does not create RDA archives. Issue was introduces with release of version 10.
This error has been fixed.
Item ID: 267411
Version: 12.00 Build: 162090
Version: 11.00 Build: 161931
Version: 10.00 Build: 162215
    • Redundant License Configuration
      Starting from zenon version 8.00 it is possible to share each license over the CodeMeter network. This allows you to have a dedicated license server. The license server can be any PC or virtual machine which runs CodeMeter. One license for two ...
    • Checklist: OPCDA Server
    • All archive files from Server 2 are synched to Server 1 in non dominant redundancy systems because of additional byte in archives.
      Description When operating in non-dominant redundancy, all archive files are always synchronized when switching redundancy from server 2 (as standby) to server 1. This means that even those files that have not changed are synchronized. ...
