Project in zenon Logic takes long time to compile and eventually Stops responding.
A zenon Logic project takes a very long time to compile and may even stop responding. This can also affect the Engineering Studio. This mainly occurs when UDFBs are shared across several projects.
This error has been fixed. Compiling a zenon Logic project works as expected again.
Item ID: 272335
Version: 12.00 Build: 220199
Version: 11.00 Build: 219314
    • Project in zenon Logic takes long time to Build external POUS when added manually
      Description zenon Logic projects take a long time to load external POUs manually. This behavior has been modified. The loading times of POUs have been significantly reduced. To benefit from this fix: Update your zenon Software Platform to the latest ...
    • AccessOPCUA: Takes very long time to start with Customer project
      Description In the Process Gateway, AccessOPCUA takes a long time to start in some projects. This is due to the number of variables contained in the project. All variables have been checked to see if they have been configured in the Process Gateway. ...
    • Logic Studio: Importing a Library in a Logic project takes very long time
      Description Importing a library into a zenon logic project took a lot of time. The issue has been addressed and the import time has been reduced. To benefit from this fix: Update your zenon Software Platform to the latest build of zenon 11 or higher. ...
