PROFINET IO Controller in zenon Logic should use max. supported length for IO/IOCS data (1440 bytes as per PROFINET standard) instead of 500 bytes used currently
supports only 500 bytes for IO/IOCS data. The standard provides 1440 bytes.
The supported length was adapted to the
standard. IO/IOCS data are now supported up to 1440 bytes.
To take advantage of this fix:
Update to the latest build of zenon 8.20, 10
or 11.
Summary When using the PROFINET controller in zenon logic, the behaviour of the controller during runtime can be unexpected when the length of IO and IOCS data exceeds the maximum size of 500 bytes or when either the option Do not wait until connect ...
When using a local Ethernet interface for Fieldbus communication in zenon Logic, you have to ensure that VLAN and/or priority settings (cf. IEEE802.1Q) are deactivated in the network adapter configuration. Therefore, go to the Network controller ...
Description When converting from zenon 12 to zenon 14, OEM specific functions and blocks for zenon Logic are marked as "not supported". This is due to a name change in the "Select" tab of the "Target System Configuration" dialog. "Logic Runtime for ...
