PROFINET - device browse doesn't work with WAGO device.
In zenon Logic, no WAGO devices are found with PROFINETControler when executing the "Browse network for slaves" command. These are present in the network, but are not listed.
This error has been fixed. When browsing with PROFINET Controler, WAGO devices are found and displayed again.
Item ID: 272234
Version: 12.00 Build: 206562
    • FAQ: Where can I find the XML device profile for COPA-DATA DNP3 drivers?
      What is a DNP3 XML device profile? Where can I find the XML device profile for one of the following drivers? DNP3_TG - Subset Level 1,2,3 and 4 for both requests and responses, DNP3 Master driver for zenon Service Engine AccessDNP3_SG - Subset Level ...
    • Setpoint input for Keyboard screen doesn’t work in Batch Control
      Description In Batch Control, the setpoint input in a screen of type keyboard does not work as expected. When entering a value via a button that is linked to the function "Setpoint input for keyboard screen", the input is not executed correctly. The ...
    • Cel print with Switch language in Sub Project from Integration Project doesn’t work.
      Summary Printing the CEL from a subproject after a language switch does not work correctly. In another language translated Keywords are not included in the Print. This behavior has been modified. Description In a project, the CEL is configured for ...
