Process Recorder: Playback startime is undefined - playback is not possible
In the Process Recorder, playback does not work. After recording, the controls for playback are grayed out in the Service Engine. The Diagnosis Viewer logs show that the start time is not defined or is out of range. The cause is that the time setting in the Process Recorder does not correspond to the Windows date/time format. This means that the start time of the playback is not correctly transferred to the simulation/playback mode.
This bug has been fixed. The time specification in the Process Recorder now corresponds to the Windows date/time format. The playback works as expected again.
Item ID: 250140
Version: 10.00 Build: 97200
