Process Recorder: Archive data creation during active playback mode
ARX files are created in the playback mode of the process recorder. This behavior has been modified.
The Service Engine creates archive files (*.arx) during the playback mode of process recorder. But during active playback mode no new data should be created at all. It is expected that archiving is disabled in active/automatic playback mode.
This behavior has been modified. If the system driver variable [process recorder]/recordermode has the value 3 or 4, no archives will be created.
New behavior in the Service Engine:
The historian is shut down when a playback is started via function, similarly to the Service Engine shut down. When playback is deactivated via function the historian is started. That behaves very similarly to the Service Engine start with the following exceptions:
  • Alternate archives are not created when the playback is stopped using the function.
  • Value changes from the drivers are not taken into account when playback is active. This can lead to the initial value for the capsule being out of date.
The historian is not started if the Service Engine starts directly in playback mode.
Reloading while playback is active reloads the historian but does not restart it.
Item ID: 280856
Version: 14.00 Build: 239777
    • Process Recorder: Time Control active in simulation and in playback mode
      Summary Time control is disabled when process recorder is in simulation or playback mode Description In the process recorder, the configured time control functions remained active even after switching to simulation or playback mode. Configured ...
    • zenon Service Engine freezes when process recorder is active
      Description The zenon Service Engine froze when the Process Recorder was active. The Service Engine froze because a Microsoft function runs in an endless loop. The issue has been addressed and an optimization call, which led to the issue, has been ...
    • Process Recorder: Playback startime is undefined - playback is not possible
      Description In the Process Recorder, playback does not work. After recording, the controls for playback are grayed out in the Service Engine. The Diagnosis Viewer logs show that the start time is not defined or is out of range. The cause is that the ...
