Issue in zenon Process Gateway IEC 60870 Slave by DPI/DCS mapping when one zenon variable is configured in a sector many times. If you create in a sector two or more IOs as 'double point information' - type id. <3>, <4> or <31> - and link with the same zenon source variable, then the mapping of the double-point value works correctly only for one IO.
issue was addressed in mapping procedure.
Issue Number: 36246
Fixed on Date: 6.4.2016
Versions: 7.50 0 BUILD 27465
