Process Gateway closes after acknowledging the error message "Memfile not large enough!" which appears immediately after startup of the Process Gateway.
When the zenProcGateway.INI file is empty the Process Gateway closes after acknowledging the error message "Memfile not large enough!" which appears immediately after startup of the Process Gateway.
This issue has been addressed by allowing the Process Gateway to start although no variables are configured.
Issue Number: 35066
Fixed on Date: 27.8.2015
Versions: 7.50 0 BUILD 25796
