Process Gateway 870 Slave: Cannot accept connections when Select Routing is activated
When a master does a connect now no longer the zenon configuration is verified. This verification is now done at the gateway startup and when a reload of the zenon project is performed. The error was caused by the expiration of the t0 timeout.
Also was increased the performance at the startup when the configuration is checked about consistence between zenon and gateway configuration and the advise of the data points when a GI was received.
Issue Number: 136826
Fixed on Date: 28.5.2018
Versions: 7.50 0 BUILD 49034 | 8.00 0 BUILD 48821 | 7.60 0 BUILD 49005
