Problems during the import of an XML file in zenon logic if ther is a parameter without value
there is a problem with the XmlParseDocFile Function Block. When there is a parameter without value (parameter="") then the FB returns that there is a "Invalid XML file or XML syntax error"
with the fix it works as expected
Issue Number: 32105
Fixed on Date: 7.7.2014
Versions: 7.11 0 BUILD 13121
